Android 10 to Android 11 production-readiness
mikeliuk
Has anyone recently done an Android update from Android 10 to Android 11 who can comment on the production-readiness of the process, and whether there are any performance or functionality issues post-upgrade to Android 11 ?
I'm currently seeing an option to update to Android 11 CAT S62 Pro v1.014.01.
Current Build number: LTE_C02011.10-N_S62Pro_0.029.00
Radio version: LTE_C0201_S62Pro
Android security patch level: 1 January 2021
Google Play system update: 1 August 2021
Baseband version: BT72_2.06-
Kernel version: 4.14.163-perf+ #1 Fri Jan 29 23:29:06 CST 2021
Build number: LTE_C02011.10_N_S62Pro_0.029.00
Leanne_T
Hi @mikeliuk
Hope you're having a lovely weekend.
If no one has any feedback on the community, you may be best asking on the manufacturer website to see if anyone has any feedback for you.
Thanks 🙂
mikeliuk
Wasn't able to find a manufacturer's forum but the update was reported known-good in a Facebook group. The update's been great over multiple days so far. 😀
One issue that I did have was opnsense+Sensei was blocking the update so it looked like it had disappeared. I had to disable the Sensei ad blocking for the update to be seen again as some IPs under reverse resolving to subdomains of 1e100.net (Google) were being blocked.
Current Build number: LTE_C02011.11_N_S62Pro_1.014.01
Android version: 11
Android security update: 1 August 2021
Baseband version: BT72_2.06-,BT72_2.06-
Kernel version: 4.19.157-per+ #1 Tue Sep 7 06:26:28 CST 2021
