For up-to-date information and comments, search the EE Community or start a new topic.  |
23-04-2021 05:43 PM
Been like it for nearly 2 days now, ee trying to fix it but taking their time! Anyone else having this problem? Everything connects fine just no signal so doesn’t work!!!
24-04-2021 08:06 AM
Hi @Dmilton57.
Have you spoken to our Tech Care team about this?
Did they update you and let you know the issue is being fixed?
Jon
24-04-2021 08:34 AM
Put the SIM from the 4GEE into a phone do you still get No Signal
24-04-2021 09:05 AM
I don’t have a ee phone
24-04-2021 09:18 AM
Doesn't need to be an EE Phone, do you have any Phone you can put the SIM in.
24-04-2021 10:48 AM
Yes I do I will try it when I get home from work
24-04-2021 03:35 PM
Tried in my phone and it works fine but just on the router
24-04-2021 06:09 PM
Not on the router
24-04-2021 06:28 PM
OK so we now know the Network is OK and the SIM seems ok.
So either a Router issue or Router Settings issue. Can you log into the Routers Homepage (normally 168.192.1.1) and check either the Profile and or the APN (access Point Name) Settings and confirm all the settings are correct. While your on that page does it give you Signal Strength or other Network Info
24-04-2021 06:42 PM
