| For up-to-date information and comments, search the EE Community or start a new topic. |
14-09-2021 07:52 AM
Windows 10 warns that this device uses a old system for security any updates to bring the system up to date
14-09-2021 08:01 AM
Login to your MBB router at http://192.168.1.1 with username/pwd as "admin"/"admin" or the admin pwd found under the battery cover. Then on the WiFi Settings tab change the WiFi to:
Security = WPA2 PSK
if it's not already, as it should be.
14-09-2021 08:01 AM
Security = WPA2 PSK
15-09-2021 11:49 AM
iPhone warns that security is weak on WPA2 also. However I have the old white square 4G Home Router and the security settings available are "Disable", WEP, WPA, WPA2, and WPA/WPA2. WPA2 PSK is not shown as available. Any suggestions? Software is up to date.
15-09-2021 01:51 PM
Hi @ChrisJD1
Thanks for posting.
Does the advice in this post help with the router that you have?
Thanks 🙂
15-09-2021 05:59 PM
Thanks Leanne,
I changed the encryption from "Automatic" to AES and the iPhone no longer warns of weak security, but other programmes are having problems connecting with the internet. I've gone back to factory settings for the moment.
Thank you.
15-09-2021 07:11 PM
AES is secure; lack of it isn't!
Thanks! You're welcome 🙂 ! Glad I could be of assistance & it is now sorted.
16-09-2021 01:02 PM
Many thanks WRaySpeX, now switched to AES and internet access fine today. Thanks again.
18-09-2021 06:45 AM
Thanks sorted
18-09-2021 11:01 AM
