close
4Gee wifi router
Andrei4417
Hey there!
Does anyone know if them Alcatel 4gee routers are unlocked and if you can use a data sim from a different provider?
Thank you all!
Northerner
Hi @Andrei4417
No they are locked to EE. If you intend to use other Sims then I would look to buy a SIM free solution from Amazon or similar.
Ok then.Thank you !
