27-11-2020 09:11 PM
We bought one last week and it was working brilliantly then someone messed about with it and now it only works some of the time and is slow or not at all other times.
Is it possible to reset it so that it is back to how it came out of the box so I can start again?
thanks
27-11-2020 09:50 PM - edited 27-11-2020 09:56 PM
Yes, @Michelle0007 , there should be a Reset hole, probably near the SIM tray, where you can push a pin in for about 10 secs.
27-11-2020 09:56 PM
thanks so much I will try that
27-11-2020 09:58 PM
Thanks! You're welcome 🙂 ! Glad I could be of assistance
