| For up-to-date information and comments, search the EE Community or start a new topic. |
23-03-2021 09:31 PM
I have had my 4GEE mini router since December and it is used away from my home to provide a WiFi connection for two Ring security cameras at a separate location.
This combination has previously worked fine.
I switched to a monthly data plan for the WiFi router last week rather than pay as you go and since then the router will not connect to the cameras, there is no problem with the Ring cameras as they are connecting to my home WiFi fine, which I did as a test to see if it was the cameras which were faulty.
Since I have had the router, once switched on, the blue lights appear initially and then go off completely. No lights stay on, the router is always fully charged.
I was on the phone for hours last week to the EE tech team going through trouble shooters, which have not worked, even with a new sim.
I'd like to know if it is possible to get a replacement router in this case as the product is faulty and I am unable to use it?
24-05-2021 04:36 PM
Yes, @EssexBoyEE , the 4GEE WiFi Mini does support both 2.4 & 5 GHz bands, but not at the same time. So you have to login & select the 1 you want.
14-07-2021 11:11 PM
I’m currently having a similar problem, mines is fully charged and I have restarted so many time, but one it turned on all 4 lights just stay blue but don’t connect to any device even charging all lights still stay blue with no flashing
15-07-2021 07:53 AM
Hi @Claudia97,
Are you using a pay as you go or pay monthly plan?
Does the coverage checker show any problems in your area? (Use the check status option)
15-07-2021 09:45 AM
15-07-2021 09:59 AM
15-07-2021 10:17 AM
@James_B It’s say service problem
15-07-2021 10:36 AM
Hi @Claudia97,
That means our network team are aware of the issue and will be working on a fix.
Please tap the 'keep me posted' button in the coverage checker so we can keep you up to date.
15-07-2021 10:59 AM
@James_B Okay thank you, it’s that why the lights are also stuck when it’s charging too because it’s normally meant to flash when charging but they all just stay blue
15-07-2021 11:19 AM
No problem @Claudia97
Yes, the lights should return to normal once it can reconnect to the network.
08-02-2022 11:58 AM
I have a mini wifi hub on pay monthly and cannot connect my ring cameras to it, is there a known problem?
