Re: iPad not connecting to network
Lee1210
Quite similar.  Internet connects to everything else except ipad. When we put the password in it says incorrect password. But the same password works for laptops and TV.
Leanne_T
Hi @Lee1210
Does the iPad connect to another other WiFi network?
Have you connected the iPad previously?
Thanks 🙂
Yes. The ipad was been used for nearly 5 yrs now. We moved house so had to get ee. But now when we log in it says incorrect password but qorks completely fine on TV and laptop.
Tell the IPad to Forget the router's network & then try again.
Leanne_T
Hi @Lee1210
Could you try the advice from @XRaySpeX and let us know if this works for you?
