on 18-10-2023 01:40 PM
Hi, has any one experienced iPhone battery drain since joining EE ?
I was transferred over from Plusnet just over a month ago and have noticed the battery on my iPhone 6s does not last half as long as it use to, checked the battery use and condition and all looks normal with a battery condition of 90%. My wife has the same phone and has experienced the same issue. The battery drain appears to be worse over night when not in use , and no app’s running in the background.
Any ideas much appreciated
on 19-06-2024 02:56 PM
on 19-09-2024 06:56 AM
If your iPhone’s battery is draining faster than you'd like, I totally get how annoying that can be. There’s no magical fix-all, but there are definitely a few things you can try that, when combined, usually make a big difference.
First off, if you’ve recently updated your iPhone, sometimes a new iOS update can cause a temporary spike in battery usage. Right after the update, your phone is busy in the background reindexing files, photos, apps, and whatnot. So if this started happening after an update, give it a couple of days and see if things settle down.
Now, let’s talk about background activity. A lot of apps run in the background, using up juice even when you’re not actively using them. You can go into your settings and take a look at Battery Usage to see which apps are the worst culprits. If you notice certain apps using way more battery than they should, you can go into Settings, and tweak things like Background App Refresh or Location Services to prevent them from running when they don’t need to. It’s worth turning off background refresh for apps that you don’t need constantly updating.
Screen brightness is another sneaky battery drainer. If you have your screen set to maximum brightness all the time, it’s going to burn through your battery. Try setting your phone to auto-brightness, which adjusts the screen based on the lighting conditions around you, or just manually lower it. It might seem small, but over time, it makes a big difference.
If you have problem persist after trying these solution, you can follow for more details assistance below.
on 19-09-2024 06:30 PM
Could be something to do with signal? As I know having no service can have an impact on your battery.
on 20-09-2024 02:25 PM
