Battery and screen fault
Leanne8240
Battery is draining quicker than normal. And then turning off. And the screen has popped out at top of the screen
Schockwave
Hello @Leanne8240 ,
Welcome to the community,
How old is your device? It sounds like the battery may be at the end of its life, depending on the age of your device.
You could try factory resetting to see if that sorts things out, but make sure you have backed everything, before doing so.
Hi It's a iPhone 11 it's just a year old. What can we do for the screen.ThanksSent from my Galaxy
@Leanne8240 , not sure why the screen has popped out of the screen. Have you rang Apple customer service? Unfortunately if you are out of warranty you would normally be liable to pay for any repairs.
Leanne_T
Hi @Leanne8240
Thanks for coming here.
If you get in touch with our Tech Gurus on 150, they will run through some trouble shooting with you and let you know what they can do to help.
