iPhone 14 Pro Max and sim
Stretchlong
Hi All
I havE upgraded from iPhone 12 Pro Max to 14 Pro Max. With the 12 I used an eSim, does the 14 come with an eSim QR code? Does it have a physical sim?
Schockwave
@Stretchlong , you can either connect with an ESim or physical sim. If you click here and then scroll down, you will see how to transfer your esim to the new phone:
https://ee.co.uk/help/help-new/getting-started-and-upgrading/setting-up-an-esim/how-do-i-use-dual-si...
@Stretchlong  With both devices on iOS 16 you can Bluetooth the eSim from the 12 to the 14.
