iPhone 17 Bluetooth not seeing devices after pairing
SueH19
I have a new iPhone 17 but it won’t stay paired to Alexa or headphones. They appear in my Bluetooth list but when I try to connect them I have to pair them again every time. If I get Alexa to pair it drops out after a couple of minutes. It’s driving me mad. I’ve changed the battery settings as recommended but is there another setting I’m missing or is there a fault?
rkelly1
Prodigious Contributor
It could be a connectivity fault.
Initially I would check for a software update under Settings - General - Software Update. If you don't have an update try resetting the network settings under Settings - General - Transfer Or Reset - Reset - Reset Network Settings
@SueH19  have you tried removing them from you’re paired list and then repairing them from scratch again.
Yes, several times, especially after powering off and restarting everything.
