redmi note 10 pro
davidthomasch
hi I have just migrated over from sky mobile to ee, and my 5g download speed is barely 2Mbps, I tested my redmi note 10 pro, using a cheap pay as you go sim on lyca ( ee network ) before I got my ee sim and I was getting 50Mbps.
Clearly the 5g bands that EE support are not the same as lyca, can any one technical suggest a work around here, as the handset is clearly capable, just EE's network isn't. Disappointly stuck now on a 24 month contract
@davidthomasch  Lyca mobile use all the bands  that EE provide. It’s the same network they don’t get their own bandwidths on EE.
Have you tried just simply restarting the device since you put the EE sim in it ?
indeed, I have even walked down to my local mast and tested with ee sim in
and then lyca sim in the device - same result
thanks for the reply
Check your APN Settings are correct for EE.
Your phone is probably Dual Sim, so again check the Sim Management for each Sim Slot is correct APN and which Sim is configured for 5G.
thank you I will try that
Done all the above max speed I get even next to the local mast, 4mbps
Even got ee to resend settings
Looks like I am stuck with this or change my handset
Wish I had stayed with sky mobile now to be honest
