Unlocking a Samsung s21 plus
Cav1904
Got IMEI 1 and 2 codes but when entering either of these to unlock the phone says there's a problem at EE end and to try again later?
Any ideas?
You can just apply for unlocking by using the Unlocking your device form and giving its IMEI no., which you can obtain be dialling *#06# into its keypad.
@Cav1904  You only need to give the IMEI for the physical SIM card slot.  (Sim 1)
