04-03-2022 07:32 AM
Hi all,. My fold 3 is around 5 months old now. I was using it, closed it up, plugged it into the charger and and hour later removed it again. On opening the inner screen now has a black line down the crease and the right side of the touchscreen doesn't work. I can see. Faint crack down the centre. Have any of you had the same problem? Lots of stories online indicate its a common problem but more worryingly that samsung won't replace the screen under warranty even though it hasn't been dropped or abused.
04-10-2022 01:01 PM
The EE service team has since been very helpful to resolve my problems. If you are getting issues with the local store please contact them as they do listen!.
04-10-2022 01:17 PM
Thanks for letting us know @Mashman29
Leanne 🙂
14-01-2023 08:33 PM
Yes currently going through the ombudsman to resolve out case as EE won't replace the screen and told us that we dropped it !
14-01-2023 08:34 PM
How did you get on with your case? I'm currently going through the ombudsman with my case about the Samsung fold
10-10-2023 08:59 PM
I have exacklty the same problem & it happend the exact same way! Defo a issue with the phone its self.. mine is under warranty still but Samsung pass the buck to Vodafone, ive never dropped my phone they say the screen isn't replaced under warranty.. its discusting and I'm fuming now stuck with a phone im still paying for i can't upgrade as ive had it less then a year samsung are useless & wont take any responsibility
11-10-2023 07:35 AM
Hi @Ammyjayne
Have you spoken to our customer care team to see what options are available?
Leanne 🙂
