10-10-2023 09:22 AM
Regular alarm unchanged for 6am, has gone off at 5am Friday and Monday morning- i double checked and no alarm set for that time. On Monday i saw the clock time change from 6am to 5am just after it happened- so with the phone using the network for its time i can only deduce that EE have been changing the time- perhaps testing for daylight savings on the 26th? either that or i am loosing my sanity- but it cant be, because my wife's alarm did exactly the same thing this morning, her's was still on network time, i had changed my settings on the phone so it doesnt use it and my alarm was at true 6am.
Anyone else?
thanks
10-10-2023 02:50 PM
deleted all alarms, set a new one and the test worked fine, i will let you know if the oddity occurs in the early hours again, to mine or my wife's phone- thanks for your support.
10-10-2023 12:09 PM
10-10-2023 12:51 PM
thanks James,
A Sony Xperia model J8210 running android 11
10-10-2023 01:13 PM
Hi @RogueTrooper1,
Is it definitely the alarm sounding, rather than a notification of an upcoming alarm?
10-10-2023 01:18 PM
hi, yes definitely the alarm.
cheers
10-10-2023 02:15 PM
Is your phone showing the correct time zone in settings @RogueTrooper1?
Have you tried cancelling all alarms and resetting them?
10-10-2023 02:20 PM
Time zone is showing the correct time zone (GMT+1 British summer time). When i turned off the automatic date and time after the alarm yesterday, i may have turned off the 'use network provided time zone' as well, i dont recall.
I will try cancelling the alarms, turning on the automatic date and time and time zone, and setting an alarm for shortly and test it....back soon! thx
10-10-2023 02:35 PM
The bi-annual clock change has been reliably performed for many years by all the UK operators, if any testing were having these symptoms, it would generate significant publicity.
You need only look at the emergency cell-broadcast test for evidence of that.
10-10-2023 02:50 PM
10-10-2023 02:52 PM
im sure, but that doesn't explain the events- if it was my phone only i'd put it down to the device but my wife's had the same last night. cheers
