Unable to connect we tv box to wifi
Starr1k
we have moved over to EE broadband, mobile and TV from BT and sky. We have been given a EE TV Box Mini, as well as the Pro Box. My son has taken the TV box mini back to uni with him (confirmed with TV team that this is allowed and would work outside of the main home). He is in student accommodation (with a TV license) but his WiFi requires you to sign in using a username and password, not just a password. When he tries to connect to this WiFi on the tv box, it says “unable to perform that action”. Anyone else had an issue with this or know a solution? There’s no physical routers in the accommodation so wired network isn’t an option.
thanks
DarrenDev
EE Product Expert
Sorry @Starr1k but you have been misinformed - the TV Box Mini will only work properly on the home broadband line.  Even if your son manages to get past the captive broadband issue (the simplest option here would be an intermediate router), none of the TV channels will work, and some of the apps will disappear from the box.  He'd get more benefit from a Fire Stick.
Who or what is providing the WiFi if it's not a nearby router. Looks like he needs 1st to create an a/c with them thereby assigning himself a username and password.
Matt_124
A lot of student accommodation use a network with Captive Portal sign-in.
The issue is likely to be a lack of browser on the EE TV Box Mini to allow signing in on the captive portal.
@Starr1k
Depending on the provider of their network, there may be a method they have in place that can be used to connect these devices to the network by registering their MAC Address and "whitelisting" them when connecting to the Access Point through the MAC authentication.
yes, he has whitelisted the wireless MAC address on the network provider but the channels will not tune over this network. The instructions on the network provider say that for full bandwidth, you must sign on to the password protected one which can only be accessed via signing into it using his username and password.
it’s a provider called Ask4. You click the password free WiFi connection, sign into your ask4 account and enable the device by whitelisting the MAC address. Then for it to work, you then connect to the locked WiFi network where he enters his username and password. It’s worked fine on his Xbox, pc and other wireless devices. Just not the EE tv box
DarrenDev
EE Product Expert
