TV Signal poor why ?
NWK22
@NWK22  Are you using an aerial or WiFi mode on the box ?
What's the best way to check ?
I assumed wi-fi ?
DarrenDev
EE Product Expert
Check the channel at position 1 in the TV Guide - is it BBC One (aerial mode) or BBC One HD (internet mode)?
If you can't tell, then check channel 101 - if it's there, you're in aerial mode.  If it doesn't exist, you're in internet mode.
Midnight_Voice
@NWK22
When did you first notice this problem, only on installing the EETV kit, or what?
If you find you are in Aerial Mode, as per the procedure described by @DarrenDev, try unplugging the aerial from the Box, and connecting it directly to the TV.
If the signal is equally poor, you need to engage a local aerial fitter to find out why and correct the problem.
If the signal is vastly improved, though, come back for more advice.
