10-03-2024 06:26 PM
I have finally got my two tv mini boxes that should have arrived with my original order almost two weeks ago after more than a reasonable amount of phone calls…
I have tried to set one up in the dining room. The router is only in the next room but it won’t pick up the WiFi?! I’ve previously had a Fire Stick in that room that picked the WiFi up without my issue. Are these TV Mini boxes useless?
27-03-2024 09:53 PM
I found the culprit. I had plugged my Virgin power line into the router and it obviously upset it. Once removed, everything worked fine. Didn’t realise the power line would not be adaptable to the new EE router.
11-03-2024 09:10 AM
Hi, @TrickyPig welcome to the community and thanks for posting, I'm sorry to see you're experiencing problems connecting your Mini TV box.
If you're having issues with your WiFi speed and connection, find out what affects your home broadband and WiFi.
Neil
11-03-2024 12:23 PM
Do the mini boxes need to connect to the smart hub directly? I know the box pro struggles when using say an eero mesh network, but does this also apply to the mini boxes?
I’ve not set mine up yet but did have problems connecting my box pro to the eero network rather than the SH WiFi.
11-03-2024 05:46 PM
I am trying to connect them wirelessly the same as I did with Amazon Fire sticks, which worked fine. Don’t understand what is stopping them.
EE’s solution is to send a power line adaptor. That’s not ideal as it is another thing to plug in. Will have to see what happens, I suppose.
11-03-2024 05:48 PM
Neil,
I’ve done all that. It just gets to set up and won’t fine the network. The router is only in the next room so should be powerful enough to reach this room. The fire sticks had no issue.
25-03-2024 12:35 AM
My EE box mini had been working until yesterday but is not now connecting now by wifi. As is the case with you, the router is only in the next room. My ipad has no problem connecting to the internet in the same room as the EE box mini.
I suspect that these ee box mini s are substandard and not fit for purpose. The change from BT to EE has not been the best and the sevice is not very good.
25-03-2024 07:27 AM
@TrickyPig wrote:I’ve done all that. It just gets to set up and won’t fine the network. The router is only in the next room so should be powerful enough to reach this room. The fire sticks had no issue.
Does everything work OK if you set up the mini box in the same room as the router?
27-03-2024 09:53 PM
