Sports HD channels not working
adam327
I was recently migrated over from BT to EE for broadband and TV, and my migrated package included 'Big Sport' (nowTV sports channels + BT/tnt sports) as well as the HD upgrade.
However, my sports HD channels on the provided ee TV box simply do not work. There is a message on the screen which says 'lets get you some more content... ' and an error code: BTP-11195c.
The HD channels worked perfectly when I was on BT...
I’m not sure if they were included in my package or not initially. If that’s the case I’m still unable to add them myself so finding the scenario frustrating. Any help with this would be appreciated.
DarrenDev
Unfortunately the HD add-on wasn't included as part of the order when you moved from BT to EE @adam327
It's not currently possible to request changes online - you'll need to call to order it again.  I can see you called yesterday, but there are no notes to say why - no orders were created though.
Darren, I'm also having troubles with getting HD channels, I have changed from BT to EE, paid extra monthly for HD but none of the channels are in HD, please can you advise?
