on 21-11-2024 05:19 PM
We have just moved over to Ee tv and have recorded a few things but can’t find how to find these recordings to watch. HELP
Solved! Go to Solution.
21-11-2024 05:27 PM - edited 21-11-2024 05:28 PM
Switch on the Box, if it’s off, and the TV, and select the input HDMI port for the Box, if the TV doesn’t do that for you.
Then press the little house symbol on the remote top left. Down arrow several times to RECORDINGS & WATCHLIST.
PIck what you want to watch if you can see it on the right, otherwise press OK to open MY TV.
All your recordings will be in there.
