Netflix code tvq-pb-101 (5.2.102) error code
Lansledj01
Getting the error code on my new EE Tv pro box on Netflix,  also Discovery+ doesn't work with another code 1k-0028 iirc. Help desk are unsure of the fix . Any ideas ? Ee broadband is 35.5mb and streaming tv ok . Mini box upstairs works ok ?
Tried
factory reset
30 sec power reset
Thanks David
8 REPLIES 8
bakerUK
I'm getting the same issue 😕
Peter_W
Good morning @Lansledj01 and @bakerUK, thanks for taking the time to highlight this.
I definitely want to make sure that this is flagged, could you please describe what exactly is happening when you get this fault?
Is it as soon as you load the Netflix app, or is it when trying to perform a particular function?
Peter
Lansledj01
Hi @Peter_W  and @bakerUK
I get the issue almost immediately I start to play a programme, on Netflix with the above code and discovery + . With the code 1K-0028. Itt suggests a restart then fails again with same code and then suggests a 30 second power reset.
I've also done a factory reset, and the help desk has done this remotely, changing from wired to wireless  all to no avail.
The issue is awaiting the back end team to resolve at present.
David
Peter_W
Thanks for confirming all of those details for me @Lansledj01.
I'm glad to hear that our technical team are on the case with this, did they mention if they'd keep you up to date on what was happening?
Peter
Vichu1
EE Product Expert
I've had the issue as well and it was resolved by connecting to the HDMI that supports UHD (HDCP 2.2) or if the TV does not support UHD, set the HDMI display to < 1080 (found inside Youview settings --> Box Management --> Picture & Sound)
@Vichu1 many thanks for this. I can now play programmes but Netflix is now showing as a small screen inthe top right of tv like a preview.  The rest are ok
Many thanks David
This thread pointed me in the right direction but couldn't stand the small Netflix so kept fiddling. Got this problem after being sent a new STB. Fixed this for a friend by setting Picture & Sound / HDMI Frame Rate Matching to On, default was off.
Had issues with Netflix, Amazon Prime, ITVX before changing this.
Davidhello123
Error code - Netflix code tvq-pb-101 (5.2.102) error code
Same problem with Netflix closing shortly after movie or TV show started
change the  setting on your EE box to be lower resolution than your TVs highest resolution my zNetflix worked perfectly after the change !
