on 08-10-2024 01:04 PM
How do I link my tv boxes together so I can save the shows I want to watch and track my progress on both my boxes simultaneously?
on 08-10-2024 01:28 PM
@NOwen1996 There is no connection between the boxes, but most of the apps on them should track your progress and allow you to pick up from where you left off.
If you add something to record or to the watchlist, it is only visible on the box you do it on.
