Juddering on streaming channels and live channels through EE TV Box Pro
How4
Valued Contributor
Valued Contributor
Hi, I have worsening screen judder through my EE TV Box pro & full works broadband. Despite many calls and an engineer visit I still get juddering. It makes no difference hard wired (Cat 7) or Wi-Fi. When I watch the same films/programmes via Wi-Fi on the Samsung Smart TV there is no issue so thinking it's tV box issue but I am on my third in a month.. When I checked the output using the Box Pro wired connection into the router the speed is 92 Mbps. Laptop via Wi-Fi is 250 Mbps & iPhone 450 Mbps.
I am told by EE techs that this is not uncommon yet they have not fixed it yet. Has anyone fixed this issue please?
44 REPLIES 44
adamwhite2810
Yes!! This happens to me. I got my box within the last few months, billed by BT, and notice that quite frequently the frame rate drops for a short amount of time before going back to normal - extremely annoying. I watch motorsport and you really notice it. However, your issue seems more severe so unsure if we're experiencing the same issue.
I'm running the box into an LG C4.
To be honest, I only watch recorded content on the box, everything live I watch on the TV apps as the frame rate is fine (showing it's an issue with the box/EE TV's service), and I know that if I report the issue to EE/BT they will not acknowledge it as a consistent issue on their service and would not resolve it, as you've proved by now being on your 3rd box.
This sort of thing always happens with big organisations - you see it on forums that numerous people experience the same thing, indicating there's something that actually needs resolving, but you report a fault and they just treat it like an isolated issue that can be sorted by turning it off and on again, and failing that, a new box, which doesn't help. It needs investigating properly but that would involve admitting there's a deep rooted issue with their service.
How4
Valued Contributor
Valued Contributor
EE have actually recognised it and seem to be working on it as I get weekly updates from 'level 2 tech' so fingers crossed.
It's worth reporting it.
Really! Fair play, that's nice to hear.
Have noticed this juddering myself so started Googling and found this thread.
I’ve gone through many of the thorough tests too. Watching live TV or say Apple TV and the inconstant frame rate is jarring. I don’t record much so I assume that’s not taxing the box too much so purely related to how the box deals with frame rates and the like.
Plugin the Xbox One and Apple TV works super smoothly on the same TV.
Peter_W
Hi @cwarrent.
Welcome to the EE Community!
Have you had a chance to test this with a different TV, or a different HDMI cable to see if the issues transfers across?
Also what model of TV are you using?
Peter
How4
Valued Contributor
Valued Contributor
Hi, EE sent out a 10m cable that made matters much worse. I was using a 5m Veetop Cat 6 cable before (which dissapeared my TV box from the network dashboard) and now ordered a Cat 6a Rhinocable. EE called to advise still not sorted but are sending a brand new box anyway - because it's started to turn my Samsung Smart TV on in the night, or refusing to boot up unless unplugged.
I don't need to check another TV as the issue does not appear if I stream through the smart TV and wifi, missing out the TV Box.
An Openreach network issue is a suspect too apparently.
Peter_W
Thanks for the update here @How4.
The reason I queried about other TVs and cables is to check the earlier theory @DarrenDev gave around issues between the framerate of the box and your TV.
Was the updates around the network issue what you were told by our Level 2 team, too?
Peter
How4
Valued Contributor
Valued Contributor
Yes, it's one of the things they are looking at.
I'm using a Phillips 4K TV (not sure of the model number at the moment).  I'm using the supplied HDMI cable from the EE box to the TV.
I've turned off motion smoothing and those kid of things that could cause inconsistencies.
I have loads of high quality HDMI cables spare but the only other TV I have is a wall mounted as a smart TV independent to stream via its OS and no way of hooking up any cables.  I'll see if I can test some other cables if you think it's commonly an issue replacing the supplied EE HDMI cables.
I have had this exact same problem since I changed over to, firstly BT tv them subsequently EE, over 2 years ago. I have a Sony Bravia Oled tv.
When I put the tv on everything is ok at first, then maybe after a couple of hours (the time can vary) I start to get a "judder" on the picture, the best way to maybe see it in it's worst is when the names of the actors etc comes up at the end of a program, it's constantly juddering, the only way I can stop it is to pause live viewing, even only for 2 or 3 seconds, them press play again and all is fine, maybe for another few hours.
I have had the technician out twice, we have tried swapping out everything, the tv box, cables, the settings on the tv and the box, nothing works except the pausing of live tv, it also doesn't matter what I am watching, normal tv programs, sport or films, it's just the same.
