on 02-04-2025 09:31 PM
Hello, since having changed from Sky to ee we now have noticed that BBC IPlayer keeps losing its Broadand connection and stops working. Anyone?
on 02-04-2025 10:18 PM
Losing it on what device?
Are any other apps affected, or just the iPlayer?
How is your device connected to broadband; WiFi, Ethernet, or via PLAs?
What does the device say about network signal strength (in Settings/Network?)
How far is the device from the router?
Any other network components involved, such as add-on repeater discs?
Might be worth a reset of the router and of the device (doesn’t need to be a full Factory Reset, something gentler should suffice to begin with).
