Hbo max app on tv Pro box
johnbhoy1979
Hi
I have the entertainment package. Signed up long before march.
Just wondering when I go onto the app I can't watch anything.
Says 'get access'   then when I click on that it says
'To get access change your plan where you originally subscribed'
I thought we should be getting automatic access to this?
DarrenDev
EE Product Expert
The HBO Max content is also available within the Now TV app, under the HBO Max heading.
If you want to enable your HBO Max "Basic with ads" subscription:
  1. https://www.nowtv.com/gb/help
  2. Click 'Need Help' in the bottom right corner
  3. Select ‘TV’
  4. Select ‘Entertainment & HBO Max Membership
  5. Select ‘Yes’ if you have an Entertainment, Big Entertainment or Full Works subscription, or a Now Entertainment & HBO Max extra on your account
  6. Select ‘I’m an EE TV customer’
  7. Select ‘Link my account so I can watch in the HBO Max app’
  8. IMPORTANT: Select whether you have Now Entertainment & HBO Max as part of your TV package or as add-on/extra
  9. Click ‘Link Now account’
  10. HBO Max web page opens
  11. Log in to HBO Max (IMPORTANT: If you have a TNT Sports subscription, make sure to use the email you use to access this in Discovery+ or HBO)
  12. You can now use your HBO Max Basic with Ads subscription across devices in your HBO Max account
DarrenDev
EE Product Expert
  3. Select ‘TV’
johnbhoy1979
Thank you Darren.  That's worked perfect.
Thank you very much for your help
