HD Channels
MrTable
Recently moved to EETV and have a main TV box and TV mini box in the bedroom. Whilst the mini TV box has fewer channels they are all in HD as they work off wifi. Is there a way of doing this on the main TV box as only the 5 terrestrial channels are coming over HD from the aerial despite having a near 100% strength and signal. Frustrating as have Now TV that are all in HD also and have considered just switching the boxes around.
Profile closed
Not applicable
@MrTable
Yes.
Do a full reset of the box (you will lose any recordings) and then set it up again from scratch without an aerial plugged in. This is the only way to switch the box mode from aerial to IP.
Couple of notes, you will only be able to record 2 channels instead of 4 and cannot skip adverts (even when recorded) on any itv content, but that is the same as the mini box.
Profile closed
Not applicable
@MrTable
Yes.
