23-05-2025 12:11 PM
Has anyone successfully got their EE Pro box to talk to the EERO Wifi? My EE Pro does not see the EERO Wifi at-all.
Thanks, David
23-05-2025 12:55 PM
Hi @dave_sussex
Have you connected the Eero via ethernet to your EE box.
23-05-2025 12:56 PM
Hi @Northerner , yes that works, but the two devices are at the opposite sides of the room, so a permanent cable is not an option.
Thanks, David
24-05-2025 02:27 PM
@dave_sussex wrote:Hi @Northerner , yes that works, but the two devices are at the opposite sides of the room, so a permanent cable is not an option.
Does eero now support multicast/IGMP as it didn’t used to and BT TV users (pre-rebrand), often had to double nat to connect wirelessly?
If Ethernet works then it suggests it does support it now, might be a question for the eero community though as technically, EE only support connecting wirelessly to an EE hub or extender.
