20-10-2026 03:45 PM
Hello,
I want to get an Eero Pro 7 in to replace my standard EE Wifi 6 hub.
I can then take advantage of the new router and possibly add an additional one as part of a mesh but are there any known issues in the basics of replacing the EE supplied hub? I've tried to search the forums for similar posts so wanted to ask...
1. Will the EE VOIP landline I use have any issues?
2. Will the EE TV box be fine working with a new router? Looking at other posts, it looks like the internet TV services and guide may be impacted?
3. I assume most of the router cabled and wifi services will work but anything else I need to know?
Thanks in advance.
20-10-2026 03:50 PM
20-10-2026 04:05 PM
Thanks for the update!
Seems like it may be quite disruptive in the short term, knocking out two core services.
My BB+TV+Phone term comes up for renewal in the next 6 months or so. I'm often looking to minimise monthly costs (so preferring to buy a router rather than pay for it monthly), so I guess if I move to a new VOIP number and maybe as planned switch to a FreeSat recorder. We're using both the landline and terrestrial TV less and less, so a workable and lower cost solution may be the better option long term.
20-10-2026 04:11 PM
You are not paying for the EE router. You are renting it for free.
20-10-2026 04:14 PM
@cwarrent As you are using the Landline very little, then take a look at A&A for the voip service, incoming is all free, outgoing very low call rate / minute as an option, EE TV is tied to EE Broadband, few streaming services available also not tied to BB provider. EE Mobile if you are on the EE one all discount's for that will be lost.
20-10-2026 04:14 PM
Sorry, I meant to say, to my knowledge if I wanted Wifi 7 I would then have to add a monthly charge for that upgrade vs buying the Eero device outright (which I'm happy to do).
20-10-2026 04:15 PM
Understood.
20-10-2026 04:18 PM
Thanks for that.
I'll make a note of that VOIP provider. I'm not sure if you can port the EE telephone number (guessing maybe not) but it may not be a great loss. Feels like there's maybe a long term plan away from EE but you never know.
20-10-2026 04:21 PM
@cwarrent They will tell you if the landline number can be ported or not.
20-10-2026 04:22 PM
I'll make a note of that for the future then. Thanks again Jim.
