EE pro box issues?
WaveyDavey59
Valued Contributor
Valued Contributor
Has anyone else found more issues using the Pro Box with EE router than the old BT Home Hub?
Especially TNT sport.
22 REPLIES 22
0scar1
Good luck and hope it works out better for you, but I have given up and cancelled my TV subscription.
Thanks DarrenDev.I can only comment in my own ignorance of technical issues or other people's comments and it seems quite a lot on here.I appreciate happy people don't post and it's only disappointed people you talk to.
Please remember I am not a tech and I can't work out how if the hub is working and I have an extender near the TV I cannot get any TV channels or sport without the aerial plug connected and why the older BT stuff worked perfectly.
The hub is in the same room about 10 metres away so I don't know where the issue would come from
I've also used powerthrough ethernet 1000 Mbps adaptors and the room was rewired by electrician late last year and still the tnt issue.
If I take out the TV aerial I get nothing.
I thank you and appreciate your responses however and the fact you interact with people.
Do they do the fixes online and how do I get contacted?
When you watch the Sport TV channels, you are tapping into a live, shared broadcast stream - it's sent to everyone at the same time. It requires perfect timing, and there's almost no time to fix errors. When enough errors have occurred, the TV Box gives up - it doesn't have enough information to show a picture, so it shows error IPC6023.  The worse the error rate on your line, the quicker the box gives up.
When you use an app like Netflix or YouTube, the app is constantly buying itself time by downloading the show a few seconds ahead of what you are actually watching. If it hits a snag, it has plenty of time to fix the error or lower the video quality before you ever notice it.
That explains why the TV Box is behaving the way it is, but we don't yet know what is causing it.  Something between your TV Box and the internet is interfering with the signal, causing data to be lost or corrupted.
All the testing will be done from our end, tracing traffic through various parts of the internet, right up until it reaches your TV Box.  You'll be contacted using the number we have registered for you.  I've added myself to the fault too, so I'll be emailed automatically with all updates - if they have any trouble reaching you, I'll let you know.
Thank you.I understand a bit more now.
Just to say here the only reason we pay for TNT Sport is to watch but mainly record UK Premiership Rugby so we can watch it at convenient time and if we can't do this it's a waste of money.Weve missed the semifinals of the Premiership already.
I am confused however with the fact that the pro box isn't faulty,the hub isn't faulty and the signal is strong then it must be the modem on the wall is a fault or fitted incorrectly?
What else can it be?
Still had no contact from level 2.
To be fair to you there I am going to allow 48 hours for resolution from now before putting in a written complaint and all transcripts to EE UK customer complaints at Sunderland and seeking compensation.
Thank you again for responding to community messages.
I genuinely don't know the cause of your issue - it's not following usual patterns. I've already said it may take time to find the fault. I can guarantee that it will NOT be resolved in the next 48 hours though, as the team don't work over the weekend.
Compensation will be applied after the fault it's fixed, to cover the time that you're without service.
It's with the right people - there's no one better to find and fix this fault. They're a small team though, and have a queue of faults.
Saturday text "We are working on it"
Sunday text "We are working on it"
Monday text "We are working on it"
Tuesday email "We've closed your complaint"
Still not working.
Is there a update to fix 6023?
@WaveyDavey59 I can't see any complaints on your account. There were 2 broadband faults open, now both closed.
The TV fault is still open, but it's tracked on a separate system.  I can see that your TV fault was updated at 9:36am today though - it's possible that Ashley (the guy looking at your TV fault) closed the broadband one at the same time?
Rest assured - the issue is still being investigated.
It looks like TNT sport is now watchable and more importantly recordable.I still have TV aerial in box for Freeview channels which are all fine.
Interested to know what the problem was.
Running ethernet through 1000 Mbps pass through adaptors (BT mini connectors) into pro box and all seems to be good.Havent tried it on WiFi alone yet but not sure it's going to give me any advantage over ethernet cable.
Anyhow thank you for your help and patience through this.
It is appreciated
Although I have to add no one actually told me,texted me or emailed me the fault was fixed and I only discovered it when I randomly tried the channel and found it working.
I would still like to know what the issue was as well.
