EE box won’t play live TV
amyenj
I’m having issues with EE TV box not playing live TV. I have EE TV box which does not have an aerial connection nor an ethernet cable connection. During the set up process the box 'found' 133 channels.
I can view anything via my apps so obviously there are no problems with the broadband speed , wifi or cable connections etc. However live TV does not work at all. I can see the guide with loads of channels but when I try to play one I just get a black screen initially which changes after some time to just a very heavily pixellated version of the screen with either no sound or an occasional squeak. Interestingly the black screen on BBC shows the green button in the top right hand corner but nothing else until the pixellated mess shows.
7 REPLIES 7
You only receive Live TV thro' an aerial. Otherwise it's just Catch-up or On Demand.
Incorrect. We have a EE TV box pro which doesn’t require an aerial. We had live tv channels up until yesterday.
Northerner
Hi @amyenj
Have you tried resetting your box.
The issue you describe does suggest the signal is not strong enough to play the content.
zulu17
Problem solver
Problem solver
Hi @amyenj
Are any error codes displayed ?
From your description your Box Pro in Ipmode  ( no aerial)  will receive those live channels via multicast delivery which is a different method to that used to provide the on demand app content.
So you appear to have a problem with the quality of the multicast delivery which might be caused at any stage of the delivery.
Hi
Yes error code is IPC6023 which comes up after a few mins.
Everything has worked fine almost a year and no changes have happened.
I have tried resetting both the box and the BT hub, connecting via Ethernet, switching off and leaving off for a while, etc, etc. Nothing seems to be working?
Having read other threads I’m wondering if it could be an EE issue?
Northerner
Hi @amyenj
https://community.ee.co.uk/t5/TV/Error-code-IPC6023/td-p/1382919
There are a few posts if you search the error code on Google for both EE and BT.
You'll need to speak to EE CS directly on 150.
zulu17
Problem solver
Problem solver
@amyenj wrote:
Hi
@amyenj  Unfortunately the root cause of the IPC6023 could be located anywhere  ie outside of your home  , within your home network, your WiFi, your home hardware. Your attempts to resolve are all sound approaches but as the problem persists you are probably going to have to rely upon EE customer support.  That might frustrating involve a wait to get through and a repeat of what you have already done and then being passed onto more technical support  ( if that is what the TMC is ). The days of a short cut to an EETV expert looking at the considerable amount of data that is amassed and reported between your box and Youview are long gone and the support teams will follow a long winding route to investigate,. Good Luck . Remember the support teams will I suspect be following a script so be patient with them , however if be wary they encourage you to give it a while and call back later.
Keep emphasising that it has been it has been working well for months , it is occurring on both wired and WiFi connection,  (the problem is not instantaneous but occurs a  few minutes after switching to channel …. Have I interpreted you message correctly here  or is  it that the error code comes up after a few minutes but that the channel is blank from the start ?)
