EE TV streaming issues Asus Router
ChrisW45
I recently signed up to EE TV "full works " and have had nothing but problems using the Pro box and mini box in another room . The HD sky sports and tnt HD channels are intermittent and when I try using the uhd tnt channel it causes the whole network in my home to shut down . I am using an Asus router and have multi cast and "IGMP Snooping enabled . When I use the now TV app and discovery plus apps I experience no streaming issues but I only suffer these issues when I use EE TV . My service is full fibre 500mb so can any one  explain why this is happening and how to fix it please
17 REPLIES 17
ChrisW45
So I think I solved my own issue . You need to limit the bandwidth of each box . I limited it to 50mbps on upload and download . This seems to stabilise the network and allow streaming in HD and UHD. I tested this a couple of times on both devices at same time and it seemed to work . More testing may be required to be deemed as a valid fix
@ChrisW45
Yes, that will probably work, as what is happening is that despite having a couple of multicast settings on the Asus router, it’s still flooding your network with multicast packets, and by limiting bandwidth you are limiting the flooding to a manageable level.
EETV take the view that they will have supplied you with a router that works with multicast, and if you want to use your own router, then you are on your own with any multicast problems you get. But there are knowledgeable customers who can help here.
Multicast is only used to deliver the EPG channels that EETV send over the internet, which is why you don’t get problems using the apps,
Further issues continue with this EE TV and causing slow down on my entire network . Are there any other solutions ? So I have limited bandwidth .  Enabled multi cast  and IGMP snooping . I don't want to use an EE router and I sent it back so don't even have it anymore . Do I have the right to cancel only had it 5 days
Weerab2024
Scholarly Contributor
You have 15 days from your contract start date to cancel just phone them up.
The sky stream device that EE sells for Sky (strange I know) works with any broadband provider so I would presume any router.
EE Apple TV box, EE mini box, Full Fibre 900, Sky Stream
@ChrisW45
Adding to what @Weerab2024 says, you could ask EETV to swap your Box Pro for the AppleTV box, which doesn’t use multicast. But then it doesn’t record either, so may not be suitable for you.
You will also have to not use any Box Minis you might have been sent, as these use multicast also.
Or I could invoke @naylor2006 who might know how to get your Asus to behave.
Timbo45
Expert Contributor
Expert Contributor
@ChrisW45
I've read of a couple of problems associated with the latest Asus routers and multicast transmissions so probably some firmware issue at the moment.
The other thing is do you use any switches in your network because not all support IGMP Snooping and that'll cause the flooding you experience.
You should always keep the ISP supplied hub as in this instance you could have just re-connected it to see if that fixed the issue - which it would possibly have done.
ChrisW45
Many thanks for the replies . I contacted EE today and told them I would send the pro and the mini back . They intend to send me an apple box . I requested if I can additional box this lead to being put on hold and eventually being cut off. I contacted them back to be told an apple box had been ordered but no mention of the secondary and I have to contact back upon arrival of this box . I don't really need a box as all it means is that I have to use Now TV and discover plus apps to watch the live content via my Google streamer .It's just very unfortunate that the set up didn't work for me even though the adviser stated that these boxes would operate on my network after I told them that I used an Asus router . Thanks again to everyone and let's hope this apple box works for me
@ChrisW45
The secondary is only ever a Box Mini. As this uses multicast, just like the Box Pro, I think you should avoid using one, as it will just re invoke your bandwidth issues.
Nobody from EETV should have told you that you could use an Asus router in place of the supplied BT or EE router without making it clear that you would need to configure it for yourself, and you would be on your own trying to get it to work 😢
As I use ethernet switches too even if I had the EE router I would had issues with the mini box . In order to get access in my other room I run an ethernet cable from the router to my media room which has multiple devices in such as TV , pc and games console , where I use an ethernet switch to give them access . I presume these boxes require direct connection to the stock router . It's been a total mess to be honest . Perhaps I should have done more research before jumping in . I just presumed that it act like any streaming service , boy was I wrong 😟. I have a reasonable understanding on configuring the router but guess it just wasn't meant to be as use switches too to grant most devices to be wired . I believe sky steam is unicast so perhaps EE will launch some sort of mini box in the future that offers unicast
