on 18-06-2025 10:57 PM
Just got a new Hisense TV and plugged in a new EE TV Box Pro for the first time. EE remote control paired with the TV perfectly and can control TV volume just fine. But when I try to select another input source, the source button on the EE remote opens up the Hisense home screen and input list, but EE remote doesn’t control the input list (directional buttons and OK button do nothing). I need to use the Hisense remote to select a source. When I return to the EE TV hdmi source, it seems the directions I’ve been pressing are just controlling the guide on the EE TV box. I’ve tried looking through various settings on both the EE box and the Hisense TV itself but can’t figure out if there’s a way to get EE Bluetooth remote to control the sources list or if I’m just doomed to using 2 remotes! Any ideas if I might be missing anything?
on 03-10-2025 09:57 AM
Hi Peter. Thanks. Yes , I've tried this, it doesn't work. Someone at EE took the make and model of my TV. Think they're trying to figure out why some TVs have this issue
on 03-10-2025 10:22 AM
Thanks @Alip87, I'm glad to hear that you've managed to check in with our team and it's been fed back - I'll flag this with some contacts at our end too.
I know on my LG TV the input menu is separate to the main TV guide and app menu, so if these are totally integrated I can see how it would prove a bit more of a technical challenge.
Peter
on 03-10-2025 10:50 AM
Yes, mine is a Hisense and I can see another person on here has the same issue with their Hisense TV
on 03-10-2025 10:59 AM
Cheers @Alip87.
Out of interest is there a dedicated inputs menu, or is the only way to change input via the main menu?
Peter
on 03-10-2025 11:18 AM
Just to explain the situation here:
The TV Box receives information from the TV via the hdmi cable. It uses this to identify make and model of the TV (depending what the TV sends - some don't send model, and don't always correctly report the make).
The TV Box uses that information to determine the best configuration.
Sometimes there is more than one matching result. When this occurs, it selects the most common configuration. There is no way to make it select the alternative - if yours isn't the most common configuration, or your TV doesn't correctly identify itself, there is no way to use the EE TV remote for it.
on 03-10-2025 11:25 AM
You have to press the source /input button. Then the various inputs come up on the left hand side. When I press the input button on my EE remote, it brings me to the input options and my home screen - not the main EE home page - so it's as if I pressed the input button on my old remote for the TV. So once that is pressed I cant even get back on to my EE home page without turning off the whole thing and turning it back on again. Its as if the main tv takes over once that input button is pressed. If there was a way to select inputs , without it changing over to the TVs home screen, then this would solve the issue.
on 03-10-2025 12:00 PM
Thanks @Alip87, it's definitely a case of what @DarrenDev mentioned in this being down to how the box interprets the settings of your TV.
Sadly with such a wide range of TV models, manufacturers and software setups out there, we're not always able to guarantee full compatibility with the EE TV remote.
Thanks for taking the time to highlight this, though.
Peter
on 03-10-2025 01:26 PM
Hi there, sorry to jump in, only just because this is all in reply to my original post! What Alip87 describes is also my original issue. When pressing input on the EE remote, the Hisense TV interprets that as bringing up the Hisense home screen, and it’s impossible to navigate with the EE remote any more. The work around I’ve found is enabling CEC on a games console, so now when I switch that on, the TV automatically jumps to that input source. It’s not perfect but it works just about. Appreciate that the EE remote can’t override the TV’s specific OS though. The perils of modern technology 😅
on 03-10-2025 01:37 PM
Hiya. To be honest, we only use the other input for the playstation, so what you've described could help us. How do you enable CEC please?
on 03-10-2025 06:01 PM
Can’t remember exactly how I did it, but on PS5 system settings, there should be an option for HDMI device link, so make sure that’s turned on. And on the TV there’s a setting for HDMI & CEC, make sure CEC control is turned on. No idea what CEC means but, magic happens, and it works. Only annoying thing is when I’m done with the PS5 and want to go back to the EETV input, I need the old remote to switch inputs. Or turn the TV off and on again 😆
