EE TV Remote flashes green not purple
adamyorkie
New EE tv customer, I've tried to set up my remote, everywhere says to reset it it should flas purple 3 times, mine only flashes green. It wont control my telly which is a c 7 year old LG. When I go on settings on the ee box and select bluetooth remote it says "unpaired" but it still works the box?
That's great to hear - it confirms there's an issue with the box or remote that you had.  We'll test them to find out what went wrong, and hopefully see if there's anything we can do to identify if others are affected too.
Please don't do anything with the old box and remote - don't reset them.  Just put them in their box, and a courier will collect it from you this week.
25 REPLIES 25
zulu17
Problem solver
Problem solver
the easy part of the explanation .
Because you haven’t succeeded in pairing the remote (Bluetooth)   it is I believe sending out IR signals that your box is responding to.
The harder part why the pairing hasn’t worked.
Have you tried a reset of the remote  and then a further pair attempt ?
https://ee.co.uk/help/tv-sport/fix-problem/reset-your-ee-tv-remote-control
Yes tried that, it also just flashed green 3 times
DarrenDev
EE Product Expert
I've just checked with the team, and the newer remotes flash aqua (EE brand colour) instead of purple (BT TV brand colour).  I'll see if we can get the web site updated.
*removed incorrect statement to prevent future confusion*
I've just checked the logs and can confirm that your TV isn't identifying itself to the TV Box, so it doesn't know how to configure the remote.  Is the TV Box connected directly to the TV with the HDMI lead supplied?
Thanks Darren, yes it is connected directly to the TV. I have used my own HDMI cable though, but it is a decent, high power one.
Would you be able to use the provided cable temporarily, just to be sure?
Also, if your TV has any ports specifically labelled to mention HDCP, use one of those instead.
We've also updated the website to mention purple or aqua, to avoid future confusion.
Now tried that, hasn't made a difference
It's made a difference at our end - it's reporting that it's connected to a 4K LG TV manufactured in Jan 2016.
I recommend trying to remote control reset one more time, just to make sure.  The box knows what it's connected to now, so if it still doesn't work then I'm afraid the answer will just be that it's not supported.
That is disappointing, still not working, I struggle to believe that my tv isn't supported, never had a problem with any other stb remotes controlling it
I agree - it's surprising, and disappointing.
It looks like you've switched back to your previous cable again - would you mind using the provided cable again just once more, so that I can get the data from your TV again?  I'll save a copy this time, and manually verify it against the known list of supported devices, just to make sure it's not a fault.
