EE TV Box
L1GHTBU1LB
Has any body had trouble with ee box using  itvx  keeps stopping through programme please .
Peter_W
Good morning @L1GHTBU1LB, welcome back to the Community!
Which EE TV Box are you using here, and is it just ITV X that seems to be affected here?
Also how is it you're connecting here, is it via WiFi or Ethernet?
Peter
CBoasty
We have the same issue across all channels… here’s an example
@CBoasty  your say all channels but the OP is about iTVX so not the same issue you have.
That image is from TNT so it’s an internet stream
Is your box via WiFi or an aerial ?  Do aerial broadcasts have the same issue?
  If via WiFi how far is the box from the router?
Profile closed
Not applicable
Sadly itvX is probably one of the worst apps on any platform.
Do you have itvX Premium or the regular version with ads? It is often where the ads are inserted (or should be), that problems occur in my experience, paying for Premium alleviated that and it generally behaves on the Pro Box for me now.
