on 20-07-2025 10:25 PM
I am wondering if the Pro remote has the same function as the Sky Stream remote?
After running Sky setup and pairing with my TV, the same power button can be used to both turn on the TV (long press) and the Puck (short press).
Does the Pro Bluetooth remote do similar? I ask because having one remote is important in my scenario.
Thanks for any tips.
Solved! Go to Solution.
on 21-07-2025 08:46 AM
Yes - the EE TV remote behaves in exactly the same way. Short press the power button to turn off the TV Box, long press to turn off the TV.
Note: this works for most TVs, but isn't guaranteed to work with them all. The only way to find out, is to try it.
