Discovery plus dropping sound after ads
Kjw22
There is no sound when whatever show we're watching comes back after the adverts. Any ideas why? Thanks
94 REPLIES 94
PaulB2005
@SoupDragon57
I know.
SoupDragon57
@Kjw22 This is the software bug we are all going is fixed. What software version is your EETV box running?
How4
Thansk for the updates. Running fine now on TV and Bose. Need to re-attach big system through new leads all round and see what happens....Thanks again!
Kjw22
Woohoo! Just watched an would Discovery without any drop out of the sound after the ads. Looks like the software fix has worked.
Thanks all.
Jonty1964
Following the update, the software page only allows for Software updates and no longer Apps updates, is this correct? Both software and APps updates coming under one button?
Jonty1964
No sound problems now. All is good.
DarrenW-Tech
EE Product Expert
The ability to check for updates to players and apps has been removed, it has been redundant for a while now as all apps silently update and check for new updates overnight 🙂
My colleagues call me Dazzler
I have the latest update 0.13.26. but still getting the sound problem, any suggestions
Garethrprice
@appy  You could try doing a soft reboot by holding the badge on the front of the box in for 8 secs and see if that resolves it
PaulB2005
Just popped back to say that it seems all is well with D+ now.
Watched a few episodes of some shows and no audio drop out 🙂
