Cannot connect to WiFi on tv
KArwa
transfered from BT to EE. They sent two wifi box so I set up the main one. It connects to all the phones but won’t connect to the Samsung tv. And then it caused the WiFi box to glitch out and restart the WiFI every time I put the password in the tv. I have tried using the IP settings. No good either. Help me
Peter_W
Hey @KArwa.
Welcome to the EE Community 😊
Just to be sure here, are you trying to connect your TV to a new EE Hub with a totally different SSID and connection key to your old BT Hub?
If you haven't already, I'd recommend deleting / forgetting the old BT Hub in your TV's settings in case this is causing any interference.
Peter
