Can you transfer recordings from one box to another?
Bouncer52
DarrenW-Tech
EE Product Expert
@Bouncer52 As others have suggested officially the answer is no, EE do not make this possible nor have ever supported it.
My colleagues call me Dazzler
Peter_W
Hey there @Bouncer52.
Welcome to the EE Community 😊
We've had a similar thread about this in the past, and normally it's not possible to swap recordings from one box to another.
Why is it you're planning on changing boxes?
Peter
I am leaving BT, and going to Vodafone, so have to send it back, have
bought a new recorder.
on bouncer on
Timbo45
Expert Contributor
Expert Contributor
@Bouncer52
When did you get the box?
If it was before 13/12/2019 then it's yours to keep.
As to copying off programmes the yes it is possible for SD recordings only but it means mounting the HDD in a Unix/Ubuntu environment copying the relevant files , renaming them to a readable format & then converting them to MP4/MKV format and then playing them via a media server.
Thank you for your replies
on bouncer on
DarrenW-Tech
EE Product Expert
