10-07-2026 08:54 PM
Hi all, currently back (I was a former bt customer)
I have 1.6gbps, got rid of sky stream due to a very annoying software bug.
Tried to add EE TV but seemingly the call centre say I can't add it after phoning up.
How can I get this added? I know it originally can't be done but I know recently it's been enabled and now you can.
Thanks in advance
11-07-2026 03:16 PM
Cheers @DarrenDev
Got to the bottom of it. I'm on a 12 month contract with a deal. This prevents adding it.
To add TV, I have to re-contract to 24 months. This isn't an issue. The issue now is broadband jumps to £80 a month alone and I can't regrade mid contract so, they are looking to try and keep it at £50 a month or close to it.
Going to let me know within the next 3 working days.
So we can mark as resolved and perhaps the online portals should add a comment as such to let the end user know of this limitation.
All three agents have been spot on with service so well done to them.
11-07-2026 08:06 AM
Sorry that you didn't get the best experience with the call centre. I can only suggest that you call again, as it is now possible to order EE TV on 1.6Gbps broadband. I can only guess you spoke to an agent who hasn't been informed.
11-07-2026 08:17 AM
I'd like to say both agents I spoke to were very pleasant and lovely to deal with.
Do you know if all agents / call centres should be aware of it?
11-07-2026 09:17 AM
It was "ring fenced" for a while (only agents in one specific team), but that was months ago. I've not heard updates for a while, but we've switched to the new ordering system for new accounts now (previously ONLY used for 1.6Gbps accounts), so I would assume that means it's fully up to speed.
11-07-2026 10:18 AM
I'll try again then.
Thankyou.
11-07-2026 03:16 PM
Cheers @DarrenDev
11-07-2026 03:20 PM
Thanks for the update @biohazardx9 - very useful information in case anyone has this issue in future. That's a great offer you managed to get on the broadband!
11-07-2026 03:22 PM
It was! EE did like a lightning deal, initially went 12 month to see how service was. It's fine vs Vodafone who had strange routing issues.
14-07-2026 09:22 AM
Further to this I have now ordered the service. And I will share the solution and any possible caveats.
1.6gbps with EE TV - requirements
if you are already on a 24 month contract with 1.6gbps
just ring up and add as you want
if you are on a 12 month contract with 1.6gbps
You will likely be told it is not possible, however it is. you will require a seperate email and the agent will have to create a completely new account. Then they will bundle everything together as you want, they'll time it so that the 12month contract will cease and the new one will start on your chosen date. You will get a warning about early termination fees by text but I am told you won't have to pay this because you aren't leaving and infact, re-contracting for longer plus adding a service so, it'll be in EE's intrest to get this over the line.
The caveat, is that a credit check will be performed regardless.
Call centers in Belfast and Newcastle (think theres two in Newcastle) both told me it wasn't possible, yet the call center in Glasgow said it was and quite happily sorted it all out. Must be the Scotch is all I can say.
So if anyone reads this - that's how you do it. - in time this will all be streamlined for sure.
