6023 error on full fibre
HywelGriff1
I know this has been raised many times but.. I was with BT until yesterday, full fibre, smart hub 2 and BT/EE box pro connected by ethernet cable. Download speed 90bmb
Today, same set up as above but on EE using the latest EE Smart box 6.  On the TV the freeview channels don't show and eventually display the ipc6023 error. The EPC guide is displayed so the channel can be chosen, but with 6023 error. All other streaming channels  work
Broadband is excellent.
What can go wrong with this change over?
Cheers.
1 ACCEPTED SOLUTION
DarrenDev
EE Product Expert
The move of your broadband from BT to EE didn't quite happen at the same time as your TV service @HywelGriff1 however they're back in sync as of about 5am today.  Let us know if it's working OK.
Chris_S
Hi @HywelGriff1 Thanks for getting in touch with us here at the community.
We have a really helpful page, where you can pop in any error codes that you get and it will display the issue and possible fixes.
To access the page, just click this link here: Error codes
Chris S
DarrenDev
EE Product Expert
Hi
Yes, the magic happened overnight!
All working now, thanks.
