on 28-01-2024 10:27 AM
28-01-2024 11:22 AM - edited 28-01-2024 11:22 AM
In what way did you set up roaming?
Often just rebooting the phone is the simple remedy. Also try selecting a network manually rather than auto. Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
