sim card not activated
jamiegrantttt
hello. i bought a new sim card on a sim only day yesterday. the sim card has been in my phone for nearly 24 hours and still hasn’t come on. what can i do
all sorted thank you very much. turned out to be a faulty sim card. put a replacement in and worked straight away
13 REPLIES 13
@jamiegrantttt  Just to check your device is network unlocked to use any network?
Northerner
Hi @jamiegrantttt
Are you in the UK.
i am yes
i believe so yes. i checked the setting and it said no sim restrictions
Christopher_G
Are you able to test the SIM in another unlocked phone, to see if it works, @jamiegrantttt?
It may be worth giving our customer service team a call so they can check everything from our side for you.
Midnight_Voice
@jamiegrantttt
Have you switched the phone off and on again?
i don’t unfortunately. was thinking of popping down to the local store tomorrow to be honest
yes i have tried a couple of times. taken. the sim out and cleans that and the port
If you are going to go down to your local store, please bring either a Passport or Driving Licence with you so they can verify you and in case they need to do a replacement SIM.
These methods are the only way they can verify you in the absence of a working SIM to send a OTP to. This ID Scan process would be required for security purposes for replacement SIMs in-store, and if you were unable to bring either of these then you would need to order a replacement SIM over the phone with customer services if that is the issue.
