forget pin
hama1ali
Hi you okay sorry my forget pin
What PIN have you forgotten?
If it's your SIM PIN, then you can enter it incorrectly a certain number of times, and reset it by using a PUK instead.
Guessing at your PUK will result in the SIM being permanently blocked.
