Will my direct debit still continue when I put old sim card into new phone?
LadyoftheLake
I needed to buy a 4G phone since my old 2/3G mobile phone stating that I needed to 'insert SIM card, which lead me to believe that the phone is no longer accepting the SIM card as perhaps EE cut the 2/3G off. This new mobile phone, which is 4G took my old SIM card, and I was able to make a phone call to another mobile phone. I wanted to confirm, is my original direct debit which was using the same SIM card, but in my old phone, still be the same in my new phone? Will I get cut off, or is the phone still still going to work, with the bill next month? Do I need to contact EE directly, or it is will it still function as is?
Thanks for taking the time to read my message.
1 ACCEPTED SOLUTION
James_B
EE Community Manager
Welcome to the EE Community, @LadyoftheLake 🙂
Yes, your plan and direct debit will continue as normal even if you're using your SIM in a new phone.
James_B
