SIM card not showing ported number
DP05
I've recently ported two numbers from BT to EE. One of the numbers has ported across OK with the SIM information showing the correct number. The second number I ported is not showing on the SIM information although the ported number comes up when calling. This is causing an issue with chat functions which use the SIM number (i.e. EE temporary number) rather than the ported number.
Both numbers are using Samsung phones so any help appreciated.
17 REPLIES 17
Alex_M
Star Contributor
Star Contributor
Hi @DP05,
When did the port take place? Is it possible that things are still going through and therefore causing the issues you are talking about?
What happens if you text NUMBER to 150 from the new sim?
Thanks,
Alex
 If I solved your issue, please click the solution button below!
 If you found my post useful, click the thumbs up button!
 To speak to EE, call 150 from your EE mobile or +44 800 079 8586 (freephone) or start a live chat.
Useful Links: My EE | Live Chat | Bills | Usage | Network Coverage Checker | Abroad | APN Settings | PM
@Alex_M
Thank you for the response.
Texting NUMBER to 150 sends back the correct ported number. Not sure yet whether the data on the phone is showing the same number.
Alex_M
Star Contributor
Star Contributor
No worries. Give your phone a reboot and the correct number should appear in settings then.
Thanks,
Alex
@Alex_M
The reboot has not changed the number showing in the SIM manager data - still the temporary EE number.
David
Alex_M
Star Contributor
Star Contributor
Please try a network reset on the phone - in settings, look for 'Reset' and then choose 'Reset Network Settings'.
It will look a little something like this.
DP05
Will that have any other unintended consequences - I don't want to lose any other data/apps etc
Alex_M
Star Contributor
Star Contributor
It will only reset the network settings, so it will refresh your mobile data settings, wifi and bluetooth settings. It won't delete any data. You may need to reconnect to your home WiFi and any bluetooth devices you use though.
It should update itself over time. if it isn't causing any issues with calling, texting and data then i would just ignore it.
Thanks,
Alex
DP05
@Alex_M
It is causing issues with RCS messaging platform as it can't verify the ported number and shows to other contacts as the temporary EE number.
David
Leanne_T
Hi @DP05
When did the number transfer?
