Re: replacement sim
Rbrowne38
I want a replacement sim the same number I lost
Linzi_H
Hi @Rbrowne38
I know you'll be eager to get a replacement SIM sorted out so you can use your services as normal!
You can get a new SIM by contacting us directly, or by visiting your local EE store with photo ID.
I hope this helps,
Linzi 😊
Linzi_H
Hi @Rbrowne38
I hope this helps,
Linzi 😊
