Re: I need a sim card replacement urgently
gustavosilva
O need sim card
@gustavosilva : Why do you need 1?
Take phone & old SIM into an EE shop with Photo ID & they'll transfer number, any SIM contacts & credit if applicable to a replacement SIM of correct size for free or order a replacement SIM online at Order a replacement SIM for £1.50 or phone CS for one. It will come as a Combi-SIM with all 3 sizes as push-outs.
You can only use the online form when you just need a different sized SIM for a new phone.
Kelly178
My phone is showing no service and emergency calls only so i might have a faulty sim card
@Kelly178 : You might or then again you might not. There could be many reason for lack of service, particularly signal & mast issues.
Leanne_T
Hi @Kelly178
Thanks for coming here.
Do ant other EE customers have signal in the same area?
Have you restarted the device?
When was the last time you used the SIM to make a call or send a text?
