Pac
KrystynaKri
I want to get a pack code to order a SIM card with unlimited internet. When I enter the code, it says that I need to call 150, since I'm changing the provider, what is it?
You only need a PAC when you are switch between diff networks.
You can switch from PAYG to a contract online by Switch to pay monthly and save . Your existing PAYG credit will be carried over as credit towards your future bills. You keep your existing SIM & no. The plan on it is just switched to contract.
8 REPLIES 8
@KrystynaKri   What code are you entering?   as you say you are entering a code ?
did you request your PAC code from you current provider ?   You do that so you can move your phone from that network over to EE.
I pay every month 30£ for 100GB, but i want to get unlimited data sim for 12 months, for this order i should write my PAC code, i have this code, but when i write there is mistake and i need to call 150 to check my code, why?
Katie_J
Hello @KrystynaKri
What network are you currently with?
Speak soon,
Katie
Oh..I don’t know, how can i check it?
Katie_J
Hi @KrystynaKri
Who do you currently pay £30 a month to?
Is it EE?
Katie
I just use the MyEE application and there I select the package for the month
Katie_J
Hi @KrystynaKri
If you are already with EE you will not be able to put your PAC code in as you can't transfer numbers.
Should you wish to change your current plan or take out an add line I would recommend giving us a call.
Katie 🙂
