05-12-2022 09:19 PM
The PAC code I received from 3 doesn’t seem to work. It’s comes up with ‘Please make sure you enter the right code. Your PAC will look like ABC123456. Your STAC will look like 123456ABC’
the 3 code starts with HTG
05-12-2022 10:56 PM
You are misinterpreting the msg. It says "looks like" not "is". "ABC" stands for any 3 letters. "123456" stands for any 6 digits.
06-12-2022 08:30 AM
Please try typing to code in manually, making sure there's no spaces before or after, @Maria123456.
