Not receiving texts or otp
Idkay_
I recently migrated from Lyca to Ee and I don’t receive texts or otp. I’m unable to access lots of my apps on my new phone. I even tried reaching 150 and I’ve not been able to get any help at all
FIZZYLP
Skilled Contributor
Skilled Contributor
Hello @Idkay_
Is your main contact number correct? If not you can change this online via the EE ID.
You should also receive OTPs via your email or secondary mobile number as a back up solution.
issue with just EE or every OTP?
Hope this helps!  If you like my reply and want to say thanks for the helpful answer then please click on the Kudos on left hand side  also if I answers your question correctly please let us know by clicking on Mark as Accepted Solution 
I’m not receiving any otps at all.
I’m also unsure how to change the ID you’re referring to.
James_B
EE Community Manager
Hi @Idkay_,
Can you receive texts from standard mobile numbers?
No I’m not receiving texts from standard mobile numbers as well.
James_B
When did your number transfer complete, @Idkay_?
Have you restarted your phone since?
